I use the script below with FastScripts to copy the current Safari web page title & URL
I activate the script with a FastScripts keyboard command.
I would like to extend the script to paste the result directly in Bike or Drafts in Rich Text format.
A big bonus - the ability to add highlighted text (if needed) from the webpage at the same time
Thank you.
tell application "Safari" to tell document 1
set the clipboard to "[" & name & "]{{ video & " URL & "}}"
end tell
Drafts is really outside the scope of this forum β I donβt know much about it, though my impression is that it is more a vehicle for plain text markup than for rich text.
If you copy a url and label from Safari or elsewhere with the Keyboard Maestro macro below, it will place Bike-pasteable rich text in the clipboard as well as a plain text MD link.
If you wanted a script which combined copying from a browser with pasting directly to a specified position in a specified Bike document, you would probably need to tell us more about how you would identify which document (and within it, where) to paste to.
Hereβs a vanilla version (for testing in Script Editor, set the language at top left to JavaScript)
It:
copies the page name and url of the front Safari document both as Bike rich text and as MD plain text, and
creates a rich text version of the link at the top of the front Bike document, if one is open.
"use strict";
ObjC.import("AppKit");
// Copy Bike and MD versions of a link to the
// front Safari page,
// and add rich text link to top of
// front Bike document.
// RobTrew @2023
// Ver 0.01
const main = () => {
const page = Application("Safari").documents.at(0);
return either(
alert("Safari page name and url to Bike")
mdVersion => mdVersion
bindLR(
page.exists() ? (() => {
label = page.name(),
url = page.url(),
md = `[${label}](${url})`,
xml = linkFromBike(url)(label);
setClipOfTextType(true)(
"com.hogbaysoftware.bike.xml"
)(xml),
setClipOfTextType(false)(
"public.utf8-plain-text"
)(md),
Right([md, xml])
})() : Left("No pages open in Safari.")
([md, xml]) => {
bike = Application("Bike"),
doc = bike.documents.at(0);
return doc.exists() ? (
doc.import({
as: "bike format"
Right(md)
) : Left("No documents open in Bike.");
// linkFromBike :: URL String -> String -> XML String
const linkFromBike = url =>
label => (
`<?xml version="1.0" encoding="UTF-8"?>
<html>
<head><meta charset="utf-8"/></head>
<body><ul><li>
<p><a href="${url}">${label}</a></p>
</li></ul></body>
</html>`
const alert = title =>
s => {
const sa = Object.assign(
sa.activate(),
sa.displayDialog(s, {
withTitle: title,
buttons: ["OK"],
defaultButton: "OK"
s
// setClipOfTextType :: Bool -> String ->
// String -> IO String
const setClipOfTextType = clear =>
utiOrBundleID =>
txt => {
clear && pb.clearContents,
pb.setStringForType(
$(txt),
utiOrBundleID
txt
// Left :: a -> Either a b
const Left = x => ({
type: "Either",
Left: x
// Right :: b -> Either a b
const Right = x => ({
type: "Either",
Right: x
const bindLR = m =>
mf => m.Left ? (
m
) : mf(m.Right);
const either = fl =>
fr => e => e.Left ? (
fl(e.Left)
) : fr(e.Right);
const fmapLR = f =>
e => "Left" in e ? (
e
) : Right(f(e.Right));
