Script to move selected task to other document with same Root Project Name
Does anybody have, or can anybody help me to create a script to move a task (no need for child/sub tasks) to an other file on top of the same root Project name?
So the content in the active TaskPaper file is (say file current.taskpaper):
  • Root Project Name:
    • Task item
    • Task item
    • Task item with sub
      • Task item selected <==
      • Task item
    • Task item
  • Other Project Name:
    • Task item
What I want to accomplish is that “Task item selected” is copied, and then the copied item is placed on top in the root of project: “Root Project Name” in a (predefined) other TaskPaper file (say overview.taskpaper). If “Root Project Name” does not exist, the project needs to be generated.
I’ve looked in the script Wiki, but found no solution in order to get the Root Project Name of selected item.
BTW, I own a copy of Keyboard Maestro.
== Thnx, Feek
The name of the target project in the target file is copied from that of the enclosing project in the source file ?
Hi @complexpoint, thnx for the prompt reply!
When “Root Project Name” in the target file exist, the copied task (only task item on cursor, no other tasks) should be placed on ‘top’ in that project (as first child). But when project “Root Project Name” does not exits in target file, the project needs to be created and the task should be place inside that “new” project.
Here’s a first draft (behind the disclosure triangle below).
The simplest approach – in scripting terms – is to let the script open the target document (if it isn’t already open).
Ver 6 (behind the disclosure triangle below), activates the target document, and gives focus to the target project.
(various other approaches to final focus are possible)
You will need to adjust the value of fpTarget (the filePath of the target file) near the top of the script source below.
[Using Scripts](https://www.taskpaper.com/guide/using-taskpaper/using-scripts.html)
Copy the whole of the source behind the disclosure triangle:
JS Source
    'use strict';
    // Rob Trew @2020
    // Ver 0.06
    // Updated to allow for proper handling of
    // square brackets in project names.
    // main :: IO ()
    const main = () => {
        const fpTarget = '~/Desktop/overview.taskpaper';
            taskpaper = Application('TaskPaper'),
            docs = taskpaper.documents;
        return either(
            alert('Problem')
            ([sourceDoc, targetDoc, projectName, taskName]) => (
                //appWinRaisedByNameLR('TaskPaper')(sourceDoc.name()),
                `${taskName} copied to ${projectName}:\n` + (
                    `in ${targetDoc.file()}`
            // Are any documents open in TaskPaper ?
            bindLR(
                0 < docs.length ? (
                    Right(docs.at(0))
                ) : Left('No TaskPaper documents open.')
                // Is any task within a project selected ?
                sourceDoc => bindLR(
                    sourceDoc.evaluate({
                        script: `${tp3SelectedItem}`
                    // Can we find or create a file at the given path ?
                    ([projectName, taskText]) => bindLR(
                        doesFileExist(fpTarget) ? (
                            Right(fpTarget)
                        ) : writeFileLR(fpTarget)(
                            `${projectName}:\n`
                        // Can we place a copy of the task in a matching
                        // project in the target file ?
                        fp => {
                                fpFull = filePath(fp),
                                targetDocs = docs().filter(
                                    x => fpFull === Path(x.file()).toString()
                                ).length,
                                targetDoc = 0 < targetDocs.length ? (
                                    targetDocs[0]
                                    taskpaper.open(fpFull)
                            return bindLR(
                                targetDoc.evaluate({
                                    script: `${tp3PlacedInProject}`,
                                    withOptions: {
                                        projectName: projectName,
                                        taskText: taskText
                                taskName => Right([
                                    sourceDoc,
                                    targetDoc,
                                    projectName,
                                    taskName
    // -------------- TASKPAPER CONTEXT --------------
    // tp3SelectedItem :: Editor -> Either String (String, String)
    const tp3SelectedItem = editor => {
                selectedItem = editor.selection.startItem,
                enclosingProjects = selectedItem.ancestors
                .filter(x => 'project' === x.getAttribute('data-type'));
            return bindLR(
                0 < enclosingProjects.length ? (
                    Right(
                        last(enclosingProjects).bodyContentString
                ) : Left('Selected item not enclosed by a project.')
                projectName => Right([
                    projectName, selectedItem.bodyString
        // ----------------- GENERIC -----------------
        // Left :: a -> Either a b
        const Left = x => ({
            type: 'Either',
            Left: x
        // Right :: b -> Either a b
        const Right = x => ({
            type: 'Either',
            Right: x
        const bindLR = m =>
            mf => undefined !== m.Left ? (
                m
            ) : mf(m.Right);
        // last :: [a] -> a
        const last = xs =>
            // The last item of a list.
            0 < xs.length ? (
                xs.slice(-1)[0]
            ) : undefined;
        // tp3SelectedItem :: main
    // tp3PlacedInProject :: Editor -> Dict ->
    // Either String String
    const tp3PlacedInProject = (editor, options) => {
                outline = editor.outline,
                project = projectFoundOrCreated(
                    outline
                    options.projectName
                outline.groupUndoAndChanges(
                    () => project.insertChildrenBefore(
                        outline.createItem(options.taskText),
                        project.hasChildren ? (
                            project.firstChild
                        ) : undefined
                editor.focusedItem = project,
                Right(options.taskText)
            type: 'Either',
            Left: x
            type: 'Either',
            Right: x
        // projectFoundOrCreated :: TP3Outline ->
        // String -> Bool -> TP3Item
        const projectFoundOrCreated = outline =>
            // A reference to a TaskPaper Project item,
            // either found in the outline, or created
            // at the top of it.
            projectName => {
                    k = projectName.trim(),
                    matches = outline.evaluateItemPath(
                        `//project "${k}"`
                    blnFound = 0 < matches.length,
                    project = blnFound ? (
                        matches[0]
                    ) : outline.createItem(k + ':');
                    blnFound || outline.insertItemsBefore(
                        project,
                        outline.root.firstChild
                    project
        // tp3PlacedInProject :: main
    // ---------- JAVASCRIPT FOR AUTOMATION ----------
    const alert = title => s => {
            sa = Object.assign(Application('System Events'), {
            sa.activate(),
            sa.displayDialog(s, {
                withTitle: title,
                buttons: ['OK'],
                defaultButton: 'OK',
                withIcon: sa.pathToResource('TaskPaper.icns', {
            s
    // appWinRaisedByNameLR :: String -> String -> IO String
    const appWinRaisedByNameLR = appName =>
        strName => {
                se = Application('System Events'),
                ps = se.applicationProcesses.where({
            return bindLR(
                0 < ps.length ? (
                    Right(ps.at(0))
                ) : Left('Application process not found')
            )(proc => {
                    ws = proc.windows.where({
                return 0 < ws.length ? (
                    Right((
                        se.perform(ws.at(0).actions.byName('AXRaise')),
                        strName
                ) : Left('Window not found by name: ' + strName);
        type: 'Either',
        Left: x
        type: 'Either',
        Right: x
    const bindLR = m =>
            m
        ) : mf(m.Right);
    // doesFileExist :: FilePath -> IO Bool
    const doesFileExist = fp => {
        const ref = Ref();
        return $.NSFileManager.defaultManager
            .fileExistsAtPathIsDirectory(
                $(fp)
                .stringByStandardizingPath, ref
            ) && 1 !== ref[0];
    const either = fl =>
        fr => e => 'Either' === e.type ? (
            undefined !== e.Left ? (
                fl(e.Left)
            ) : fr(e.Right)
        ) : undefined;
    // filePath :: String -> FilePath
    const filePath = s =>
        // The given file path with any tilde expanded
        // to the full user directory path.
        ObjC.unwrap(ObjC.wrap(s)
            .stringByStandardizingPath);
    // writeFileLR :: FilePath -> Either String IO FilePath
    const writeFileLR = fp =>
        s => {
                e = $(),
                efp = $(fp)
                .stringByStandardizingPath;
            return $.NSString.alloc.initWithUTF8String(s)
                    efp, false,
                    $.NSUTF8StringEncoding, e
                    Right(ObjC.unwrap(efp))
                ) : Left(ObjC.unwrap(e.localizedDescription));
Wow, great @complexpoint. You make my day!
I’ll dig into this tonight (CET), and hopefully I finally understand all the JS-code.
== Feek
Works completely! Thnx!!!
one small issue. In some project names I have square brackets, like:
[201217] Some Project Name
I expect in the search something needs to be escaped, because projects are duplicated, so they “were not found”
Interesting :slight_smile:
I think I’ll start by deferring to @jesse’s view on the best approach there.
The problem, I think, is that square brackets (and in particular, square brackets containing numeric strings) have a role in TaskPaper’s itemPath query language, and that means that outline.evaluateItemPath can’t, in the case of those project names, directly match a search of the pattern
//[201217] Some Project Name
Experimenting with ⌘⇧F (View > Begin Editor Search) I notice that simply escaping the square brackets doesn’t immediately allow for a match.
Jesse can probably tell us whether the TaskPaper parser and the itemPath parser both recognise square brackets as valid characters in project names, and if they do, then what the correct escape pattern might be.
Ah … I should have thought of this:
//"[201217] Some Project Name"
I’ve now updated the script (behind the disclosure triangle in the original post) to flank that part of the query with double quotes.
and @Jesse kindly reminded me that it would be more focused to write:
"project [201217] Some Project Name"
so the projectFoundOrCreated function now adopts that pattern too in version 3.
Yes! You nailed it!
Thnx again for making this script for me! I really appreciate it! I also saw you have already added this script to the wiki :slight_smile:
== Feek
I think we owe that to the quiet and generous actions of an editor – I was as pleased to find it there as you were : -)
Hi @complexpoint,
Really thx for the script! Works great.
I’ve one more request. Is it possible to get focus on the project in the target file like ⌘-P (Menu > Palette > Go to Anything) . Because for example when in the target file focus is on a project, and you add / copy an item, you have no focus on that specific project.
== Feek
Ver 6 (updated behind the disclosure triangle in the original posting above)
now leaves the target document in the foreground, and narrows its focus to the target project.
( Let me know if that’s not quite what you are after )
Yess!! Exactly as I wanted :slight_smile:
And of course the best wishes for 2021!!
== Feek
Thanks ! and a good year to you and yours, as well : -)
