This Alfred workflow runs the following inside TaskPaper to show and move the cursor to an item given it’s id.
function TPContext(editor, options) {
editor.itemPathFilter = ''
var item = editor.outline.evaluateItemPath('@id = ' + options.id)[0]
editor.forceDisplayed(item, true)
editor.moveSelectionToItems(item)
It seems work well, but will not move the curser from the sidebar if I’ve just selected a project or saved search with it. Hitting Tab will then move the cursor to the item which must have been selected properly behind the scenes.
So, is there a way to force the cursor from the sidebar into the editor?
If I understand you I think you want:
editor.focus()
It’s an undocumented method right now, but I’ll make it public if it solves the problem. Let me know.
Also in your script you could make it a little simpler by using:
editor.outline.getItemForID(options.id)
Instead of evaluateItemPath.
Thanks Jesse. This is exactly what I want and it works great. Thanks also for the getItemForID hint. For reference I’ve ended up with:
// Show an item in TaskPaper and clear path filter
var item = editor.outline.getItemForID(options.id)
editor.focus()
