While the GUI helpfully lets us look before we leap, (inspect a URL visually before we follow a link) there may be moments at the start of work when we want to batch-open all the links in all selected rows, without needing to visually inspect them first.
Here’s a Keyboard Maestro version, bound by default to ⌘J
Bike Outliner – Open all links in selected lines - Macro Library - Keyboard Maestro Discourse
and here’s the script itself, for testing in Script Editor.app (with language selector at top left set to JavaScript) or for using with other launchers, like FastScripts or Alfred.
See: Using Scripts - Bike
"use strict";
ObjC.import("AppKit");
// Directly open (leap without look)
// any links in the selected Bike rows.
// main : IO ()
const main = () => {
message = alert(
"Open links in selected rows"
return either(message)(
xs => 0 < xs.length ? (() => {
links = nub(xs.map(
x => x.attributes.href
return Object.assign(
Application.currentApplication(), {
.doShellScript(
links.map(x => `open "${x}"`)
.join("\n")
links.join("\n");
})() : message(
"No links found in selected rows."
fmapLR(
filterTree(
x => Boolean(x.attributes.href)
dictFromHTML(
doc.export({
selected: true
as: "bike format",
all: false
// ----------------------- XML -----------------------
// dictFromHTML :: String -> Either String Tree Dict
const dictFromHTML = html => {
error = $(),
node = $.NSXMLDocument.alloc
.initWithXMLStringOptionsError(
html, 0, error
return Boolean(error.code) ? (
Left("Not parseable as XML: " + (
`${html}`
) : Right(xmlNodeDict(node));
// xmlNodeDict :: NSXMLNode -> Node Dict
const xmlNodeDict = xmlNode => {
unWrap = ObjC.unwrap,
blnChiln = 0 < parseInt(
xmlNode.childCount, 10
return Node({
content: blnChiln ? (
undefined
) : (unWrap(xmlNode.stringValue) || " "),
attributes: (() => {
const attrs = unWrap(xmlNode.attributes);
return Array.isArray(attrs) ? (
attrs.reduce(
(a, x) => Object.assign(a, {
[unWrap(x.name)]: unWrap(
x.stringValue
blnChiln ? (
unWrap(xmlNode.children)
.reduce(
(a, x) => a.concat(xmlNodeDict(x)),
const alert = title =>
s => {
const sa = Object.assign(
sa.activate(),
sa.displayDialog(s, {
withTitle: title,
buttons: ["OK"],
defaultButton: "OK"
s
// Left :: a -> Either a b
const Left = x => ({
type: "Either",
Left: x
const Node = v =>
// more child trees.
xs => ({
type: "Node",
root: v,
nest: xs || []
// Right :: b -> Either a b
const Right = x => ({
type: "Either",
Right: x
const either = fl =>
fr => e => e.Left ? (
fl(e.Left)
) : fr(e.Right);
// filterTree (a -> Bool) -> Tree a -> [a]
const filterTree = p =>
// List of all values in the tree
// which match the predicate p.
foldTree(x => xs =>
p(x) ? [
[x], ...xs
] : xs
).flat(1)
const fmapLR = f =>
e => "Left" in e ? (
e
) : Right(f(e.Right));
const foldTree = f => {
const go = tree => f(
tree.root
tree.nest.map(go)
return go;
// nub :: Eq a => [a] -> [a]
const nub = xs =>
[...new Set(xs)];
// MAIN ---
