I’m experimenting with using TaskPaper for some basic qualitative analysis of focus groups. It’s search functionality combined with tagging makes it a great app for a simple analysis. However, when I using longer text (interview snippets) I really notice that there’s no right-side padding between border and text. There is left-side padding (mainly for the light gray circles & lines). Possible to add some right-side padding in the future so longer text doesn’t bump up right against border wall?
Yeah I see what you mean. I’ll balance it out a bit for the next release.
@jessegrosjean: That’s great to hear! Many thanks. I’m seeing more and more uses for TaskPaper the more I use it. And those uses can be pretty different from a simple task manager.
