Recurring Tasks, Fuzzy Dates, and migration scripts
I’m just getting back into TaskPaper after a few years away. I rewrote a couple scripts in JXA that I use the most to be compatible with 3.9.4 and add some features. I also created some migration scripts to help with Markdown task transfers.
Recurring Tasks
Fuzzy Dates
Taskpaper to Markdown
Markdown to Taskpaper
Thanks for sharing. Just in case you missed it, TaskPaper also supports a similar fuzzy date syntax:
So for example TaskPaper > Edit > Insert Date
And then type 3d and you’ll get date 3 days from now inserted.
Thanks Jesse. Yes, I’m aware of the new date picker which is a great addition. I have found that rapid entry of tags with fuzzy dates with keyboard macros via Espanso is still faster for me than pulling up the date picker.
