I’m a new user of WriteRoom and noticed that, when trying to switch windows using the Command ` keyboard shortcut, WriteRoom cycles through all my open tabs as well as my open windows. So, if I have four tabs open in one window, and a separate window open containing a single document, I have to cycle through all four of my tabs before I get to the separate window. I hope that makes sense.
Is that how WriteRoom is intended to work? If so, would you consider changing WriteRoom to match how all my other Mac apps work, which is to NOT cycle through tabs when using Command ` to switch windows. I will often have a set of reference files open in tabs in one window, and then a document that I’m working on open in a separate window, and want to toggle quickly between both windows. Having to cycle through all my tabs in order to do that really slows me down.
