I just started playing around with Bike and absolutely loving it so far. I was a big fan of Workflowy back in the day and then moved to Bear and iAWriter (love their focused and typewriter mode). Bike seems like the best of all worlds.
I had a couple of questions:
Is there a project/file explorer where I can see all my files in a left sidebar and quickly open them?
Is there any chance there’s an early black-friday discount code available?
There isn’t. It is something that I think would improve Bike and that I plan to eventually add, but it’s still quite far down the road. Current focus is Bike 2. Once that’s done then I will start aiming towards Bike for iOS, and I “expect” that will have a file browser UI that will also make it into the Mac version. This is all quite far in the distance I think.
Sure this is 20% off, expires later this week (Oops, here’s actual code):
To compensate, I’ve tried to make a shortcut suite that helps! It’s much more manual, but the idea is to have a Bike document act as your hub. And when you create new documents, you do it from this hub document.
I tried to make it easy-ish for others to import the shortcuts, but I get it if it’s a bit too complicated, heh.
