I’ve changed the text color of @done lines in user.less, but in project lines, the colon doesn’t change color. Is there something I’m missing or a workaround?
The problem is in run[display]. That means only apply the attributes to text runs that have the display attribute. That attribute is not applied to leading or trailing syntax. Try deleting [display] to see the difference.
Thanks! Also played around a bit more and figured that I’ll just keep the entries like those already available for @today, that way the tags retain their colors when there’s a bunch of them.
