Hi Hub,
I can’t print. Choosing “File, Print” gets me to the print page, but only for a flash and then the program closes entirely. Anyone else experiencing this?
I’m running on Sierra, version 10.12.2
Hi Hub,
Hi, please see:
Thanks, that worked! I had to go into Security settings to allow it, but just printed. You replied quickly and that’s much appreciated. I use Writeroom now instead of Word, especially when I’m getting started and don’t want to distract myself with mindless formatting.
My best,
s
Having same problem. Will check the zip and see what happens.
Fixed. Thank you!
Works for me too. It is a shame I didn’t go to the support forum earlier. I think it is sad development actitvity is low atm, but it is understandable. I would love to see a fully compatible version however.
