Hello everyone!
I have a quite old document that I’ve been editing for years (like a notebook), and I’d like to restore all previous versions of the file. I already tried restoring them one by one using “Revert to”, but it will take me years! There are hundreds of saves. I was wondering where the saves are in the hard disk… there should be a folder or something, right? It would be much easier to get the files this way.
Thanks for your help.
On my computer the old document versions are stored at file paths like this:
file:///System/Volumes/Data/.DocumentRevisions-V100/PerUID/501/29418/com.apple.documentVersions/com~hogbaysoftware~TaskPaper_38018093-0DFC-4E20-88CA-5BFF854E9505_5c1.taskpaper
Not sure if that will help or not… that’s the file that document is being read from when I look in debugger.
It did help, thank you!
