PaperTrail for iOS/iPadOS (1.1, released)
Hello! I am around, busy building the app :slight_smile: @GPHD
I believe you were on the TestFlight at one point? Did you leave it?
I can imagine… No, I forgot to do it, and now it seems closed.
Check your DM
Done, Thanks !
TestFlight
I will submit as final tomorrow if no bugs are found
PaperTrail 1.1 (260503.2345)
  • add: Import from Reminders — pull any Reminders list into the current document, with notes, subtasks, dates, completion, alarms, priority and flags mapped to tags
  • add: Shortcuts/Siri “Import Reminders List” action with a list picker and spoken confirmation
  • add: What’s New menu command (View menu) to reopen the release notes panel on demand
  • add: Long-press the toolbar Indent/Outdent buttons to operate on the whole branch
  • add: Long-press Move Up/Down menu now also offers Move Branch Up/Down alongside the section moves
  • add: Toolbelt buttons for Command Palette and Goto Anything
  • add: Icons throughout the iPadOS menu bar and command palette
  • add: What’s New, Website, Support available from Command Palette
  • change: Improved the size and shape of fold marker tap area
  • change: Improved Sidebar layout and styling
  • change: Renamed some commands
  • change: Improved scrolling and hiding keyboard behaviour
  • fix: One focussed-folding behaviour had regressed
  • remove: Edge swipe-to-dismiss gesture on the sidebar
  • chore: Added RemindersImporter unit tests
button for hiding keyboard now works perfectly! Thanks so much for this (and the other improvements)
Unfortunately, it doesn’t work.
Oli
Hi !
  1. Focus on a note.
  2. Press enter and see what happens.
  3. Press enter again and see what happens.
Please, don’t be cryptic. Just post a screenshot or screen recording or explain what happens.
For example, I’m focused on a note and I’m typing enter and everything is fine, new items are added, in 1.1 (260503.2345)
This is why we need steps to reproduce or a description of the problem.
Description of problem:
Expected results:
Actual results:
Thank you
Sorry, but this week I cannot take so muche time. The bug occurs when you are at the beginning of a focused note.
That was the missing piece. I can reproduce :ok_hand:
@GPHD @matt
Where is your cursor positioned before you focus into a node? Before the hyphen, somewhere in the middle of the text, or at the end of the text? That determines where your cursor will be placed after focusing. The right side of the text is unproblematic. If you press Enter now, the subtask will be indented directly as a child node.
However, if you place the cursor before focusing in front of the hyphen, it will also appear there after focusing. If you press Enter now, the cursor jumps to the front of the hyphen. If you press Enter again, the parent node suddenly disappears and only reappears after you focus out. That seems to be a bug.
My current workaround: no matter where your cursor is before focusing in, focus into the node and press Cmd/Enter. The node will then be indented properly as expected.
Oli
But how do you want us to press Cmd on iPhone ?
Just press the +Button at the bottom toolbar :slightly_smiling_face:
Oli, please send me the text you are using to test @cost(…)
I found a bug where I do not ask for a cost refresh until the cursor is moved after an edit.
But I’m intrigued if your issue is different
Shortcut keys listed in the app are mostly meant for hardware keyboard (Bluetooth, USB) or iPad. And for me testing on Simulator.
For iPhone all function are available in a menu on the (new) tool button.
@matt
It would be helpful if the Cost(sum) tag calculated the total relative to the current filtered view. Keyword: income/expense tracking (for example @insurance, @groceries, @hobby,@clients etc.). I know that the grand old lady “Omni” can do something like this. Would that be possible, Matt?
Oli
for you, I will see what I can do!
new build in the next couple hours
done in new version 1.1 (260503.1625)
Perfect! You are also a true poet! :slightly_smiling_face:
