I would like an option to replace the check box with the original TP2 dash. I use TP for outlining, and not everything is a task.
I’d love to have this option as well.
I’ll try to get this in with the theming system.
I would like this option too.
+1 for this as I often use TaskPaper as an outliner.
+1 on this idea - but good to have both options, outliner by default, todo list with – or [] behavior?
+1 for this too. I mostly treat dashed lines as just more accentuated items, as lines that stand out from the grey note lines which I use for mostly everything.
