Mundus: Python Script to format OPML files saved in Bike to proper OPML 2 specifications (vibecoded)
Hello everyone! Laura here
I’m a brand new user of Bike, and so far I’m loving the app (and plan to get a license soon – thank you @jessegrosjean for your hard work on Bike – but at the moment I’m broke since most of my money went to buying a MacBook Neo). But since I also have Scrivener installed, I found that the way Bike creates OPML files to be janky under the hood (and thus incompatible with other OPML apps). So with the help of Claude AI, I created Mundus, a little Python script that allows you to turn OPML files created in Bike to proper OPML 2.0 specifications. The code is down below:
mundus.py — Cleans up a messy OPML file and makes it proper OPML 2.0.
(Mundus: Latin for 'clean' and 'world' — cleaning up your messy OPML world!)
Usage:
    python mundus.py
It will ask you a few questions interactively!
What it fixes:
  - Adds version="2.0" to the <opml> tag if missing
  - Removes non-standard tags from <head> (e.g. <meta charset>)
  - Adds a <title> to <head> if none exists (using the filename)
  - Removes non-standard attributes from <body> (e.g. id="...")
  - Warns you about any <outline> text that looks cut off (ends mid-sentence)
  - Optional strict mode: Removes non-standard attributes from <outline> elements
  - Optional notes mode: Turns child text outlines into _note attributes
  - Fixes indentation so the file is nicely readable
Requires:
    pip install colorama
import sys
import os
from xml.etree import ElementTree as ET
from colorama import init, Fore, Style
# autoreset=True means every print() automatically goes back to normal colour
init(autoreset=True)
# ── Handy shortcuts for coloured prefixes ─────────────────────────────────────
OK   = Style.BRIGHT + Fore.GREEN   + "[ OK ]" + Style.RESET_ALL + " "
FIX  = Style.BRIGHT + Fore.CYAN    + "[FIX ]" + Style.RESET_ALL + " "
WARN = Style.BRIGHT + Fore.YELLOW  + "[WARN]" + Style.RESET_ALL + " "
ERR  = Style.BRIGHT + Fore.RED     + "[ERR ]" + Style.RESET_ALL + " "
INFO = Style.BRIGHT + Fore.BLUE    + "[INFO]" + Style.RESET_ALL + " "
DONE = Style.BRIGHT + Fore.MAGENTA + "[DONE]" + Style.RESET_ALL + " "
# ── Helpers ──────────────────────────────────────────────────────────────────
def looks_cut_off(text: str) -> bool:
    Returns True if the text looks like it ends mid-sentence.
    stripped = text.strip()
    if not stripped:
        return False
    word_count = len(stripped.split())
    if word_count <= 6:
        return False
    ending_ok = ('.', '!', '?', '…', '"', '\u201d', "'", ')', ']', '-')
    return not stripped.endswith(ending_ok)
def process_outlines(elem):
    Recursively processes outlines to merge note-like children/siblings
    into _note attributes. Returns the number of notes merged.
    notes_merged = 0
    # First, process all children recursively so bottom-up merging happens
    for child in list(elem):
        notes_merged += process_outlines(child)
    # Now process the direct children of this element
    new_children = []
    i = 0
    children = list(elem)
    while i < len(children):
        child = children[i]
        # If it's an RSS feed, leave it entirely alone
        if child.get("xmlUrl"):
            new_children.append(child)
            i += 1
            continue
        child_text = child.get("text", "").strip()
        child_word_count = len(child_text.split())
        is_long = child_word_count > 6
        has_children = len(child) > 0
        # Is this outline a "heading"? (Short text, or has sub-headings/feeds)
        if not is_long or has_children:
            # Check if the next siblings are "notes" (long text, no children)
            notes = []
            j = i + 1
            while j < len(children):
                sibling = children[j]
                sibling_text = sibling.get("text", "").strip()
                sibling_word_count = len(sibling_text.split())
                is_sibling_long = sibling_word_count > 6
                has_sibling_children = len(sibling) > 0
                if (not sibling.get("xmlUrl") and
                    is_sibling_long and
                    not has_sibling_children):
                    notes.append(sibling_text)
                    j += 1
                else:
                    break # Next sibling is a heading or RSS feed, stop.
            if notes:
                # Merge these notes into the heading's _note attribute
                existing_note = child.get("_note", "")
                if existing_note:
                    existing_note += "\n\n"
                child.set("_note", existing_note + "\n\n".join(notes))
                notes_merged += len(notes)
                # The notes are consumed, so we skip them in the loop
                i = j
            else:
                i += 1
        else:
            # This is a long, childless outline, BUT it's not following a heading.
            # If it's the ONLY child, it's probably the parent's note.
            if len(children) == 1 and not elem.get("xmlUrl"):
                existing_note = elem.get("_note", "")
                if existing_note:
                elem.set("_note", existing_note + child_text)
                notes_merged += 1
                # Don't add child to new_children, it's merged into parent!
                i += 1
            else:
                # It's a standalone long outline among other things.
                # Leave it as a child outline to be safe.
                i += 1
    # Replace the old children with the new processed children
    elem[:] = new_children
    return notes_merged
# ── Main fixer ────────────────────────────────────────────────────────────────
def fix_opml(input_path: str, output_path: str, strict: bool, make_notes: bool):
    print(f"\n{INFO}Reading: {input_path}")
    try:
        tree = ET.parse(input_path)
    except ET.ParseError as e:
        print(f"\n{ERR}Could not read the file — it has broken XML: {e}")
        sys.exit(1)
    root = tree.getroot()
    # ── Stats tracking for the final summary ──────────────────────────────────
    stats = {
        "version_fixed": False,
        "head_tags_removed": 0,
        "title_added": False,
        "body_attrs_removed": 0,
        "outline_attrs_removed": 0,
        "notes_merged": 0,
        "cut_off_warnings": 0
    warnings = []
    # ── 1. Fix <opml> root tag ────────────────────────────────────────────────
    if root.tag != "opml":
        print(f"{ERR}This doesn't look like an OPML file (root tag isn't <opml>). Stopping.")
        sys.exit(1)
    if root.get("version") != "2.0":
        old_ver = root.get("version", "none")
        root.set("version", "2.0")
        stats["version_fixed"] = True
    # ── 2. Fix <head> ─────────────────────────────────────────────────────────
    head = root.find("head")
    if head is None:
        head = ET.SubElement(root, "head")
    # Remove non-standard elements (like <meta charset="utf-8"/>)
    allowed_head_tags = {
        "title", "dateCreated", "dateModified",
        "ownerName", "ownerEmail", "ownerId", "docs",
        "expansionState", "vertScrollState",
        "windowTop", "windowLeft", "windowBottom", "windowRight"
    to_remove = [child for child in head if child.tag not in allowed_head_tags]
    for child in to_remove:
        head.remove(child)
        stats["head_tags_removed"] += 1
    # Add <title> if missing
    if head.find("title") is None:
        default_title = os.path.splitext(os.path.basename(input_path))[0]
        title_elem = ET.SubElement(head, "title")
        title_elem.text = default_title
        stats["title_added"] = True
    # ── 3. Fix <body> ─────────────────────────────────────────────────────────
    body = root.find("body")
    if body is None:
        print(f"{ERR}No <body> found in this OPML file. Stopping.")
        sys.exit(1)
    # Remove ALL attributes from <body> (OPML spec says it shouldn't have any)
    if body.attrib:
        stats["body_attrs_removed"] = len(body.attrib)
        body.attrib.clear()
    # ── 4. Fix <outline> elements ─────────────────────────────────────────────
    all_outlines = root.iter("outline")
    # Added _note and note to the allowed list so they don't get stripped!
    allowed_outline_attrs = {"text", "type", "xmlUrl", "htmlUrl", "description",
                              "language", "title", "version", "url", "created",
                              "isComment", "isBreakpoint", "category", "_note", "note"}
    for outline in all_outlines:
        text = outline.get("text", "")
        # Warn about cut-off text
        if looks_cut_off(text):
            warnings.append(f'"{text}"')
            stats["cut_off_warnings"] += 1
        # Only strip attributes if the user chose STRICT mode
        if strict:
            extras = [a for a in outline.attrib if a not in allowed_outline_attrs]
            for attr in extras:
                del outline.attrib[attr]
                stats["outline_attrs_removed"] += 1
    # ── 5. Convert to _notes (if requested) ───────────────────────────────────
    if make_notes:
        stats["notes_merged"] = process_outlines(body)
    # ── 6. Pretty-print ───────────────────────────────────────────────────────
    ET.indent(root, space="  ")
    # ── 7. Write output ───────────────────────────────────────────────────────
    # We write to a string first so we can fix the ugly &#10; newlines in attributes
    xml_string = ET.tostring(root, encoding="UTF-8", xml_declaration=True).decode("utf-8")
    xml_string = xml_string.replace("&#10;", "\n")
    with open(output_path, "w", encoding="UTF-8") as f:
        f.write(xml_string)
    # ── 8. Print Warnings (if any) ────────────────────────────────────────────
    if warnings:
        print(f"\n{Fore.YELLOW}{'─'*55}{Style.RESET_ALL}")
        print(f"{WARN}Found {stats['cut_off_warnings']} outline(s) that may be cut off.")
        print(f"     Please check these manually and fill in the missing text:\n")
        for w in warnings:
            print(f"     {Fore.YELLOW}{w}{Style.RESET_ALL}\n")
        print(f"{Fore.YELLOW}{'─'*55}{Style.RESET_ALL}")
    # ── 9. Print Final Summary ────────────────────────────────────────────────
    print(f"\n{DONE}{'─'*43}")
    print(f"{DONE} MUNDUS CLEANING REPORT")
    print(f"{DONE}{'─'*43}")
    ver_status = f"{Fore.GREEN}Yes{Style.RESET_ALL}" if stats["version_fixed"] else f"{Fore.YELLOW}No (already 2.0){Style.RESET_ALL}"
    title_status = f"{Fore.GREEN}Yes{Style.RESET_ALL}" if stats["title_added"] else f"{Fore.YELLOW}No (already existed){Style.RESET_ALL}"
    print(f"  OPML version updated to 2.0:     {ver_status}")
    print(f"  Non-standard <head> tags removed: {Fore.CYAN}{stats['head_tags_removed']}{Style.RESET_ALL}")
    print(f"  Missing <title> added:            {title_status}")
    print(f"  Non-standard <body> attrs removed:{Fore.CYAN}{stats['body_attrs_removed']}{Style.RESET_ALL}")
    if strict:
        print(f"  [Strict] Outline attrs removed:   {Fore.CYAN}{stats['outline_attrs_removed']}{Style.RESET_ALL}")
    else:
        print(f"  [Strict] Outline attrs removed:   {Style.DIM}Off{Style.RESET_ALL}")
    if make_notes:
        print(f"  [Notes]  Text blocks merged:      {Fore.CYAN}{stats['notes_merged']}{Style.RESET_ALL}")
    else:
        print(f"  [Notes]  Text blocks merged:      {Style.DIM}Off{Style.RESET_ALL}")
    warn_color = Fore.YELLOW if stats['cut_off_warnings'] > 0 else Fore.GREEN
    print(f"  Cut-off text warnings:            {warn_color}{stats['cut_off_warnings']}{Style.RESET_ALL}")
    print(f"\n{OK}Saved fixed file to: {output_path}")
    print(f"\n{DONE}Mundus complete! Your OPML world is clean and valid.\n")
# ── Entry point ───────────────────────────────────────────────────────────────
def main():
    print(f"\n{INFO}Welcome to Mundus! Let's clean up your OPML world.")
    # 1. Ask for input file
    while True:
        input_path = input(f"\n{Style.BRIGHT}Where is the messy OPML file?{Style.RESET_ALL} ").strip()
        if not input_path:
            print(f"{ERR}Please enter a file path.")
            continue
        if not os.path.isfile(input_path):
            print(f"{ERR}File not found: {input_path}")
            continue
        break
    # 2. Ask for output file
    base, ext = os.path.splitext(input_path)
    # Here is the change! Using " (clean)" instead of "_fixed"
    default_output = f"{base} (clean){ext or '.opml'}"
    output_path = input(f"{Style.BRIGHT}Where should I save the fixed file?{Style.RESET_ALL} (Press Enter for: {default_output}) ").strip()
    if not output_path:
        output_path = default_output
    # 3. Ask for strict mode
    strict_input = input(f"{Style.BRIGHT}Strict mode?{Style.RESET_ALL} Deletes extra attributes like 'id'. (y/N) ").strip().lower()
    strict = strict_input == 'y'
    # 4. Ask for notes mode
    notes_input = input(f"{Style.BRIGHT}Notes mode?{Style.RESET_ALL} Turns child text into _note attributes. (y/N) ").strip().lower()
    make_notes = notes_input == 'y'
    # Run the fixer
    fix_opml(input_path, output_path, strict, make_notes)
if __name__ == "__main__":
    main()
Let me know what you all think.
I’m glad you were able to get what you needed working.
Can you describe what specific workflows were creating problems for you with Bike’s current OPML. But does add some extra attributes needed to maintain Bike features, but that’s pretty standard with XML formats and generally reading applications just ignore.
Well, I’d appreciate it if OPML notes could be displayed in Bike (like OmniOutliner), but it’s not really a deal breaker (though, it would be handy). It’s more the fact that Bike’s OPML out of the box doesn’t follow the OPML 2.0 specs, but now that I have Mundus made, it’s more an annoyance than a demand for you.
I’m still not sure where Bike’s added attributes are breaking processes. For example I can open a Bike OPML and it opens into OmniOutliner OK. I guess if there’s something specific you think I need to change regarding the OPML support let me know.
Bike doesn’t support OmniOutliner style notes, where a note is really just a new attribute added to a row. But Bike does support “note” typed rows. Use Format > Row > Note. Or when typing if you just start a new row by typing : followed by a space it will change the new row to a note type.
Yeah, I noticed the Note menu option during my trial, but this is exactly the annoyance I have and what I built Mundus for: not being able to see where notes are connected (because they’re treated as different nodes). OmniOutliner makes this seamless, but as I said, it’s not a dealbreaker, and I can work around it.
The _note attribute is not actually part of the OPML 2 specification – just a proprietary innovation by the Omni group – but it’s one which Scrivener can makes use of via its OPML import options:
Scrivener > Settings > Import & Export > OPML:
We could write a Bike extension which copies a specialised OPML source to the clipboard – folding the text of consecutive type="note" child rows (with that of their descendants) into the value of a _note=String attribute.
(Something like Copy as Scrivener OPML, or Copy as Omni OPML)
(though I don’t think Scrivener knows how to paste from an OPML (public.data.xml.opml) pasteboard – you would have to paste into an empty text file, and save with an .opml extension, before importing or drag-dropping the file to Scrivener)
Or perhaps an osacript, to write out the specialised OPML file.
I’ll take a quick look later in the week.
Yes, I’m aware, and I have that checkbox ticked. Proprietary or not, the support for notes is extremelly useful as a visual aid (especially for an ND person like me).
What is that?
osascript can be AppleScript or JavaScript for Automation – in this case it would be the latter.
Not as fast as a Bike extension, but it’s a way of running scripts in a context which has access to the filesystem, for writing out a specialised OPML file.
Oh, I see.
I updated Mundus for Bike 2.0, BTW.
import sys
import os
    if not stripped:
        return False
    if word_count <= 6:
        return False
    notes_merged = 0
    new_children = []
    i = 0
        child = children[i]
            i += 1
            continue
            notes = []
            j = i + 1
                    is_sibling_long and
                    not has_sibling_children and
                    sibling_text != ""):
                    j += 1
                else:
                    break
            if notes:
                if existing_note:
                i = j
            else:
                i += 1
        else:
                if existing_note:
                notes_merged += 1
                i += 1
            else:
                i += 1
    return notes_merged
    try:
        sys.exit(1)
    stats = {
        "notes_merged": 0,
        "cut_off_warnings": 0,
        "ghosts_removed": 0
    warnings = []
        print(f"{ERR}This doesn't look like an OPML file. Stopping.")
        sys.exit(1)
    # ── 1. Aggressive Head Cleaning ────────────────────────────────────────────
    if head is None:
    allowed_head_tags = {"title", "dateCreated", "dateModified", "ownerName", "ownerEmail"}
        head.remove(child)
    # ── 2. Clean Body ──────────────────────────────────────────────────────────
    if body is None:
        print(f"{ERR}No <body> found. Stopping.")
        sys.exit(1)
    if body.attrib:
        body.attrib.clear()
    # ── 3. The Ghost Hunter (Remove empty outlines) ───────────────────────────
    # We walk through the whole tree and look for outlines that have no text,
    # no children, and no URL. If we find one, we delete it entirely.
    for parent in root.iter():
        for child in list(parent):
            if child.tag == "outline":
                has_text = child.get("text") and child.get("text").strip()
                has_url = child.get("xmlUrl") or child.get("htmlUrl")
                if not has_text and not has_url and not has_children:
                    parent.remove(child)
                    stats["ghosts_removed"] += 1
    # ── 4. Clean Outlines (Attributes) ────────────────────────────────────────
    # Now that ghosts are gone, we clean up the remaining attributes.
    all_outlines = list(root.iter("outline"))
    # We ONLY allow these. Everything else (like created/modified) is banned in strict mode.
    allowed_outline_attrs = {"text", "xmlUrl", "htmlUrl", "description", "title", "_note", "note"}
        text = outline.get("text", "").strip()
        if strict:
            # Create a list of things to delete so we don't mess up the loop
            to_delete = [a for a in outline.attrib if a not in allowed_outline_attrs]
            for attr in to_delete:
    # ── 5. Notes Mode ──────────────────────────────────────────────────────────
    if make_notes:
    # ── 6. Final Cleanup and Save ─────────────────────────────────────────────
        f.write(xml_string)
    # ── Report ────────────────────────────────────────────────────────────────
    if warnings:
    print(f"  OPML version updated to 2.0:     {Fore.GREEN if stats['version_fixed'] else Fore.YELLOW}{'Yes' if stats['version_fixed'] else 'No'}{Style.RESET_ALL}")
    print(f"  Junk <head> tags removed:        {Fore.CYAN}{stats['head_tags_removed']}{Style.RESET_ALL}")
    print(f"  Missing <title> added:           {Fore.GREEN if stats['title_added'] else Fore.YELLOW}{'Yes' if stats['title_added'] else 'No'}{Style.RESET_ALL}")
    print(f"  Body attributes removed:         {Fore.CYAN}{stats['body_attrs_removed']}{Style.RESET_ALL}")
    if strict:
        print(f"  [Strict] Outline clutter removed:{Fore.CYAN}{stats['outline_attrs_removed']}{Style.RESET_ALL}")
    else:
        print(f"  [Strict] Outline clutter removed:{Style.DIM}Off{Style.RESET_ALL}")
    print(f"  Empty 'ghost' lines removed:     {Fore.CYAN}{stats['ghosts_removed']}{Style.RESET_ALL}")
    if make_notes:
    else:
    print(f"\n{OK}Saved fixed file to: {output_path}\n")
def main():
    while True:
        if not input_path or not os.path.isfile(input_path):
            print(f"{ERR}File not found. Try again.")
            continue
        break
    output_path = input(f"{Style.BRIGHT}Where should I save it?{Style.RESET_ALL} (Enter for: {default_output}) ").strip()
    if not output_path:
    strict_input = input(f"{Style.BRIGHT}Strict mode?{Style.RESET_ALL} (Deletes timestamps/IDs) (y/N) ").strip().lower()
    notes_input = input(f"{Style.BRIGHT}Notes mode?{Style.RESET_ALL} (Merge long text into notes) (y/N) ").strip().lower()
    main()
