organizing row now is a little tricky.
like
- list
- 1
- 2
- 3
- 4
I want to select and drag 2, 4 or 1, 3 at a time.
like
Remember that 3 is part of 2, and naturally travels with it there.
If you want to move 2 and 4 (without 3) you will need to perform multiple operations. Bike doesn’t support discontinuous selection. But if you internalize Bike’s keyboard shortcuts those multiple operations are quite quick. If I want to move 1, 3 to a new location I would probably:
Is this a functional trade-off, or that may be considered/supported in the future?
