Moving item to project moves cursor
Hey,
I regularly go through my inbox project and move items to the projects they should be in - to tackle them later in focus bursts.
Now, when I move any items from “Inbox:” to “Test:” the items move just fine, but the cursor also jumps there. Is there a way to deactivate that?
Update: Just realised - when I look at only the Inbox in a separate tab, then the cursor won’t move with the item, but stay. Is that intended?
thx
Not currently, but I agree that’s probably the wrong behavior. I’ll get that fixed for a future release.
Yes, though like I said above I think generally the cursor should not ever move with the items.
I was just having the exact same thoughts about the cursor moving when going through my Inbox. Great that’ll be fixed in future versions!
This should be fixed in:
