Installed TaskPaper Preview 173 and the sidebar feature does not expand when using toolbar icon or from the view menu.
I have reinstalled a twice but it does not resolve. Is this a code error?
This is a bug that only affects OS X 10.10 I think. I just noticed it myself when doing some work on my laptop. Assuming that’s it (you have OS X 10.10) then it will be fixed in the next update.
Same problem I’m having. Had been inconsistent, now it’s just not there. Tried the “make the window bigger” suggestion you made, no effect. I’m running OS X 10.10.5. Will keep on the lookout for the update.
Yes, I confirm that I am using OS X 10.10.5. Hopefully the update fixes it. Thanks
Just installed update. Still no sidebar. Yar.
I tried a fix but couldn’t manage it for the 3.0 release. I am quite certain that the sidebar is there on the left, just 1pixel wide. If you can click that 1pixel region and drag to the right it should show up.
LOL, bingo! Grabbed the 1 pixel wide sidebar and dragged right. Thanks! That would explain the “twitch” when you enable/disable the sidebar. Once it’s been expanded, when you save, close, and open the file, it remains in place.
Confirming fix in Version 3.0.1 Preview (183) release. Thanks!
