Minor question - file opening order on launching
Quick q - what determines the (re-)opening order of files on launch; and therefore the active window when the documents all launch? It isn’t alphabetical.
I have 3 active documents and i would like to reliably have the same one open and frontmost each time i re-launch Bike.
Scriptable, FWIW, since each document has a unique id, targetable by a bike link.
Perhaps a pair of scripts/macros:
  1. Save current document setup, and
  2. restore last saved setup.
Could be bound to keystrokes with something like Keyboard Maestro or FastScripts.
It should be that it restores the ordering that they were in when you quit Bike.
