I notice, (Bike 1.4 Preview 69
), that if formatting runs start or end within a word, as in the partial italicisation of Epsilon below:
then we are getting a slight problem (in build 69) in the browser display of Bike HTML – whitespace gaps appear before and after the formatting run:
Perhaps newlines in the .bike
HTML pretty-printing are interpreted by the browser as syntactically significant soft breaks ?
<li id="GD">
<p>
<span>Ep</span>
<em>sil</em>
<span>on</span>
</p>
</li>
The browser display drops the intruded spaces if we reformat to:
<li id="GD">
<p>
<span>Ep</span><em>sil</em><span>on</span>
</p>
</li>
(FWIW the Pandoc HTML parser also interprets those mid-word pretty-print line endings as semantic SoftBreak
tokens)
(The Pandoc abstract syntax tree can be inspected by writing out to its native
format)
pandoc -f html -t native sample.bike -o sample.ast
Expand disclosure triangle to view Pandoc AST
[ BulletList
[ [ Div
( "40" , [] , [] )
[ Para [ Str "Alpha" ]
, BulletList
[ [ Div ( "Hh" , [] , [] ) [ Para [ Str "Beta" ] ] ]
, [ Div ( "WM" , [] , [] ) [ Para [ Str "Gamma" ] ] ]
, [ Div ( "f2" , [] , [] ) [ Para [ Str "Delta" ] ] ]
, [ Div
( "GD" , [] , [] )
[ Para
[ Span ( "" , [] , [] ) [ Str "Ep" ]
, SoftBreak
, Emph [ Str "sil" ]
, SoftBreak
, Span ( "" , [] , [] ) [ Str "on" ]
This is just a bug that I don’t have a good solution for yet.
When reading Bike files I don’t follow all the HTML conventions… in particular I only read text from leaf nodes, and I treat that read text as pre-formatted… so I don’t do things like collapse multiple spaces into a single space.
I think “maybe” the solution is to stop using the framework provided pretty print and instead construct the XML document with my own pretty print implementation… which puts everything within the <p>
element on the same line.
