Marked 3: including Bike outlines as Mermaid mindmaps
As of today’s Version 3.0.18 (1147) of Brett Terpstra’s new Marked 3 previewing app, Bike outlines can be transcluded inside Markdown documents, and displayed as mindmaps.
Thus from:
## Here is a heading
And some text before the inclusion.
<<[~/Desktop/Condillac1798.bike]
with some more text after.
to something like:
(notice the zoom etc controls)
To enable Mermaid transclusion of Bike outlines in Marked 3, check:
Marked 3 > Settings ... > Apps > Mind maps and outlines > Bike outlines
Initial caveat:
Just enabled by a release today, and I notice one glitch (already reported) – for some reason it doesn’t yet tolerate the use, within Bike outline text, of a closing curly brace character }.
(Perhaps unescaped and clashing with some Mermaid syntax ?)
If you need to use } in the context, for example of citation references like:
{Condillac, 1798 #10539}
then, empirically, a temporary fix turns out to be to double the bracketing
{{Condillac, 1798 #10539}}
(Which makes me wonder whether an XSLT template transform is at work somewhere in Marked or Mermaid)
Thanks for the tip!
The link to Marked 3 isn’t working for me. Not sure if it’s a forum problem, or just bad link?
Is there a release notes page with this mention?
Thanks – link above fixed and pointing here:
Marked - The Ultimate Markdown Preview and Converter
Bike inclusion as Mermaid mindmap is detailed in the Marked docs here:
and appeared in the changelog today:
Changelog – Version Marked 3.0.18 (1147)
This is very useful!
Though, I wonder if there are more glitches in the rendering? I can’t seem to get some Bike files to render as diagrams with more than the filename displayed:
others end up with a syntax error (same .bike file opens normally in Marked):
Or maybe I’m just doing something wrong. I do hope this eventually gets ironed out by Marked devs.
I exactly received the same syntax error, but don’t know why, I will post this to Marked forum.
Just one dev, I think.
It will be helpful to Brett if you can post a minimal and reproducible example here: https://support.markedapp.com
Now fixed in Marked Version 3.0.19 (1148)
Thanks for pointing people to this @complexpoint. I’ve done a terrible job of keeping up with informing all of the app developers I add support for…
Thanks for including Bike!
i tried this with V3.0.25, but got the same error
Something to log with the Marked support forum, I think.
( worth isolating what is choking it, if you can - progressively subdividing your document into a residual half that works, and a half that fails ?)
Something Brett hasn’t seen ? CJK punctuation ? Rarer emoji ?
