I’m not entirely sure, because I don’t know details of Logseq Markdown. But it looks like a similar idea to Bike’s markdown… ensure everything is in nested list. Given that I think this can be useful if you want to convert non-list markdown it a list form for Bike.
With the help of ChatGPT, I’ve written two Python scripts to convert BikeMD-style Markdown text into regular Markdown text and the other way around.
Bike md to md script:
- Removes YAML frontmatter.
- Reads the document line by line and skips blank lines.
- Calculates hierarchy from indentation using tabs or 4 spaces.
- Removes inline IDs if present.
- Converts
- # Headingnodes into Markdown headings based on indentation level. - Limits heading depth to H6; deeper BikeMD levels are still exported as H6, not H7 or beyond.
- Converts
- ---into an HTML page break. - Converts
- normal textnodes into Markdown paragraphs. - Converts
+ itemnodes into Markdown unordered list items. - Preserves numbered list lines such as
1. item. - Normalizes extra blank lines and outputs clean Markdown.
Bike > md
#!/usr/bin/env python3
import re
import sys
def remove_frontmatter(text):
lines = text.splitlines()
if lines and lines[0].strip() == "---":
for i in range(1, len(lines)):
if lines[i].strip() == "---":
return "\n".join(lines[i + 1:])
return text
def clean_inline(text):
text = re.sub(r"\s*\{#[^}]+\}", "", text)
text = re.sub(r"\[([^\]]+)\]\{strong\}", r"\1", text)
text = re.sub(r"\[([^\]]+)\]\{emphasis\}", r"\1", text)
text = re.sub(r"[ \t]+$", "", text)
return text
def indent_level(prefix):
tabs = prefix.count("\t")
spaces = prefix.replace("\t", "")
return tabs + (len(spaces) // 4)
def convert_bikemd_to_md(text):
text = remove_frontmatter(text)
out = []
for raw in text.splitlines():
if not raw.strip():
continue
line = raw.rstrip()
prefix = line[:len(line) - len(line.lstrip(" \t"))]
level = indent_level(prefix)
stripped = line.strip()
# Standalone Bike/Pandoc ID line
if re.fullmatch(r"\{#[^}]+\}", stripped):
continue
# Bike node
if stripped.startswith("- "):
content = stripped[2:].strip()
content = clean_inline(content)
if not content:
continue
# Horizontal rule / page break
if content == "---":
if out and out[-1] != "":
out.append("")
out.append('<div style="page-break-after: always; break-after: page;"></div>')
out.append("")
continue
# Heading node
if content.startswith("#"):
m = re.match(r"^(#+)\s+(.*)$", content)
if m:
title = m.group(2).strip()
heading_level = min(level + 1, 6)
out.append("")
out.append("#" * heading_level + " " + title)
out.append("")
continue
# Non-heading Bike node becomes paragraph
out.append("")
out.append(content)
continue
# Unordered list node from +
if stripped.startswith("+ "):
content = clean_inline(stripped[2:].strip())
out.append("- " + content)
continue
# Numbered list lines stay numbered
if re.match(r"^\d+\.\s+", stripped):
out.append(clean_inline(stripped))
continue
# Other lines
content = clean_inline(stripped)
if content:
out.append(content)
md = "\n".join(out)
md = re.sub(r"\n{3,}", "\n\n", md)
return md.strip() + "\n"
if __name__ == "__main__":
if len(sys.argv) == 3:
input_path = sys.argv[1]
output_path = sys.argv[2]
with open(input_path, "r", encoding="utf-8") as f:
input_text = f.read()
output_text = convert_bikemd_to_md(input_text)
with open(output_path, "w", encoding="utf-8") as f:
f.write(output_text)
else:
input_text = sys.stdin.read()
print(convert_bikemd_to_md(input_text), end="")
md to Bike md script
- Reads the Markdown document line by line.
- Converts ATX headings (
#to######) into BikeMD heading nodes using indentation-based hierarchy. - Converts normal paragraphs into BikeMD paragraph nodes prefixed with
-. - Converts Markdown unordered lists (
-,+,*) into BikeMD unordered list nodes prefixed with+. - Preserves Markdown ordered list numbering such as
1. item. - Detects paragraph-following lists, with or without blank lines, and indents those lists under the preceding paragraph.
- Converts indented Markdown code/paragraph lines into one-level-deeper inline code span nodes.
- Preserves fenced code blocks as literal BikeMD child lines.
- Converts Markdown tables into BikeMD outline blocks marked with
`Tablo`. - In table conversion, bolds header names and separates header/value pairs with
|for easier reverse conversion. - Converts Markdown horizontal rules into BikeMD
- ---page-break markers. - Preserves blockquotes as normal BikeMD paragraph nodes.
- Outputs clean BikeMD text with indentation defining the hierarchy.
md > Bike md
import re
import sys
TAB = "\t"
MAX_HEADING_LEVEL = 6
return text
return re.sub(r"[ \t]+$", "", text)
def clean_cell(text):
text = text.strip()
text = re.sub(r"<br\s*/?>", " / ", text, flags=re.IGNORECASE)
text = re.sub(r"\s+", " ", text)
return text
def bold(text):
return f"**{text}**"
def is_alignment_row(cells):
if not cells:
return False
for cell in cells:
c = cell.strip()
if not re.fullmatch(r":?-{3,}:?", c):
return False
return True
def split_table_row(line):
line = line.strip()
if line.startswith("|"):
line = line[1:]
if line.endswith("|"):
line = line[:-1]
return [clean_cell(cell) for cell in line.split("|")]
def make_unique_headers(headers):
result = []
counts = {}
for i, header in enumerate(headers, start=1):
h = header.strip()
if not h:
h = f"Kolon {i}"
if h in counts:
counts[h] += 1
h = f"{h} {counts[h]}"
else:
counts[h] = 1
result.append(h)
return result
def normalize_row_length(row, header_count):
row = list(row)
if len(row) < header_count:
row.extend([""] * (header_count - len(row)))
if len(row) > header_count:
extra = row[header_count:]
row = row[:header_count]
row[-1] = " | ".join([row[-1]] + extra)
return row
def is_table_line(line):
return line.strip().startswith("|")
def collect_table_lines(lines, start_index):
table_lines = []
i = start_index
while i < len(lines):
line = lines[i]
if not line.strip():
break
if not is_table_line(line):
break
table_lines.append(line.rstrip())
i += 1
return table_lines, i
def table_lines_to_bikemd(table_lines, base_indent):
table_lines = [
line.rstrip()
for line in table_lines
if line.strip()
if len(table_lines) < 2:
return []
headers = split_table_row(table_lines[0])
headers = make_unique_headers(headers)
data_lines = table_lines[1:]
if data_lines and is_alignment_row(split_table_row(data_lines[0])):
data_lines = data_lines[1:]
out = []
out.append(f"{base_indent}- `Tablo`")
for line in data_lines:
row = split_table_row(line)
row = normalize_row_length(row, len(headers))
first_header = headers[0]
first_value = row[0] if row else ""
out.append(
f"{base_indent}{TAB}- {bold(first_header)} | {first_value}"
for header, value in zip(headers[1:], row[1:]):
out.append(
f"{base_indent}{TAB * 2}- {bold(header)} | {value}"
return out
def heading_to_bikemd(line):
m = re.match(r"^(#{1,6})\s+(.+?)\s*#*\s*$", line)
if not m:
return None
level = min(len(m.group(1)), MAX_HEADING_LEVEL)
title = clean_inline(m.group(2).strip())
indent = TAB * (level - 1)
return f"{indent}- # {title}", level
def current_content_indent(current_heading_level):
if current_heading_level <= 0:
return ""
return TAB * current_heading_level
def md_indent_level(prefix):
spaces = len(prefix.replace("\t", ""))
return tabs + (spaces // 4)
def is_indented_code_candidate(line):
m = re.match(r"^([ \t]+)(.+)$", line)
if not m:
return False
md_prefix, _ = m.groups()
is_indented_code = (
"\t" in md_prefix
or len(md_prefix.replace("\t", "")) >= 4
is_list_item = (
re.match(r"^[ \t]*[-+*]\s+", line)
or re.match(r"^[ \t]*\d+\.\s+", line)
return is_indented_code and not is_list_item
def is_unordered_list_line(line):
return re.match(r"^([ \t]*)([-+*])\s+(.+)$", line)
def is_ordered_list_line(line):
return re.match(r"^([ \t]*)(\d+\.\s+.+)$", line)
def is_paragraph_like_before_list(line):
if not stripped:
return False
if heading_to_bikemd(stripped):
return False
if is_table_line(line):
return False
if is_indented_code_candidate(line):
return False
if is_unordered_list_line(line) or is_ordered_list_line(line):
return False
if re.fullmatch(r"[-*_]{3,}", stripped):
return False
if stripped.startswith(">"):
return False
if re.match(r"^(```+|~~~+)", stripped):
return False
return True
def next_nonblank_line_is_list(lines, start_index):
i = start_index + 1
line = lines[i]
i += 1
continue
return bool(
return False
def convert_md_to_bikemd(text):
out = []
in_fenced_code = False
fence_marker = None
current_heading_level = 0
pending_paragraph_parent = False
list_after_paragraph = False
i = 0
raw = lines[i]
line = raw.rstrip("\n")
i += 1
continue
fence = re.match(r"^(```+|~~~+)", stripped)
if fence:
marker = fence.group(1)[0]
indent = current_content_indent(current_heading_level)
out.append(f"{indent}- {clean_inline(stripped)}")
if not in_fenced_code:
in_fenced_code = True
fence_marker = marker
elif marker == fence_marker:
fence_marker = None
i += 1
continue
if in_fenced_code:
out.append(f"{indent}- {clean_inline(line)}")
i += 1
continue
converted_heading = heading_to_bikemd(stripped)
if converted_heading:
bike_line, current_heading_level = converted_heading
out.append(bike_line)
i += 1
continue
table_lines, next_i = collect_table_lines(lines, i)
converted_table = table_lines_to_bikemd(table_lines, indent)
if converted_table:
out.extend(converted_table)
i = next_i
continue
content = re.sub(r"^[ \t]+", "", line)
content = clean_inline(content.strip()).replace("`", "\\`")
out.append(f"{indent}{TAB}- `{content}`")
i += 1
continue
m_ul = is_unordered_list_line(line)
if m_ul:
md_prefix, _, content = m_ul.groups()
extra = md_indent_level(md_prefix)
if pending_paragraph_parent:
list_after_paragraph = True
paragraph_extra = 1 if list_after_paragraph else 0
out.append(
f"{indent}{TAB * (paragraph_extra + extra)}+ "
f"{clean_inline(content.strip())}"
i += 1
continue
m_ol = is_ordered_list_line(line)
if m_ol:
md_prefix, content = m_ol.groups()
out.append(
f"{indent}{TAB * (paragraph_extra + extra)}"
i += 1
continue
out.append(f"{indent}- ---")
i += 1
continue
i += 1
continue
if (
and next_nonblank_line_is_list(lines, i)
pending_paragraph_parent = True
else:
i += 1
return "\n".join(out).strip() + "\n"
output_text = convert_md_to_bikemd(input_text)
else:
print(convert_md_to_bikemd(input_text), end="")
Usage
I use both scripts as clipboard filters from the terminal.
Markdown to Bike MD
pbpaste | python3 /path/to/md_to_bikemd.py | pbcopy
- Copy normal Markdown text to the clipboard.
- Run the command.
- The script reads the clipboard content with
pbpaste. - It converts Markdown into BikeMD outline format.
- The converted output is written back to the clipboard with
pbcopy. - Paste the result into Bike.
Bike MD to Markdown
pbpaste | python3 /path/to/bike_to_md.py | pbcopy
- Copy BikeMD outline text to the clipboard.
- Run the command.
pbpaste. - It converts BikeMD outline format back into normal Markdown.
- The converted Markdown output is written back to the clipboard with
pbcopy. - Paste the result into any Markdown editor.
