Jesse could you write down a list of differences…?
For instance if I drag a file from the Finder in TP it produces an abs link in Bike…nothing?
Sorry, I lost track of this post… dragging a file from the finder should create a link to the file in Bike also. The big difference is that in a normal Bike document the link created will be a “rich text” link. You will see the filename, and the full file URL will be stored associated with that text, but not visible the editor.
actually you did answer… in another thread
