I would like to create links to other items in my TaskPaper files. Is this possibile? I can’t find it in the manual, nor in these help answers.
Thank you,
Paolo
Thank you,
Paolo
No, nothing is built in. It is something that I’d like to work on eventually, but it’s a tricky problem with plain text files… there’s no place to store a unique id for each entry.
The closest built in option right now is to create saved searches in the sidebar.
Don’t [[Wikilinks]] essentially work as inline saved searches? So that if this was implemented it just acts as a hot-link to that ‘unique term’.
This of course goes back to Notational Velocity, NVAlt, the recent The Archive and 1Writer (iOS).
