Hi there!
I’ve been using WriteRoom for many years.
Last version has kept me a bit stumped with the way it handles preferences, which I’m sure has been a topic of conversation.
I would ideally have a single Preferences area for all of it, because at least I know that any settings applied there will be program-wide. Or for Themes to include all font and paragraph options.
I can get with the new system as it is, except…
At the moment, there doesn’t seem to be a way to change the spacing options that translates to a different document. Or indeed, the same document that I close and open again. I set it to 1.5 and for some reason it won’t go back to the original setting.
I just can’t change the setting in a way that will be program-wide. It resets every time.
Am I missing something? Is there a different way to change spacing besides Format > Text > Line Spacing?
Or is this a problem with some preferences file not updating, having incorrect system permissions, etc?
PB
