License code has already been utilized
Same problem. Trying to use TaskPaper on a new work computer (so, 1 at home, 1 at work). I’m sure it was on an old one in the past that I never deactivated. Thanks, if you can deactivate the others.
Saw this, then lost track of it. Anyway, I’ve just reset your license, should work to register again now.
Works perfectly now. Thanks!
Hi @jessegrosjean
I’m having the same trouble with a license activated on a prior computer that I no longer have. Been a while since I’ve used TaskPaper but coming back to try it out again. I’ve tried the Paddle site but it is not helpful. Could my prior activations be deactivated so I can use again on my current 2 laptops? Not sure if you can see my email as forum admin or if need to get to you another way. Thanks.
Yes, I’ve just reset your activations, should work on a new computer.
