Jim
1
Hello all,
I am trying to figure out a way to select projects by their position.
If I search using:
project [0]
…then I get the first project.
If I search using:
project [1]
…then I get the second project, and so on. This makes sense to me.
However, if I search for:
project [0] or [1]
…then I get nothing.
Am I on the wrong track using slices? Ideas?
My understanding of the slice indexes is that they express subsets of a search result.
For stretches of adjacent peers returned by searches like project or //project, you can write things like:
//project[2:5]
(which would yield up to three consecutive peer projects)
For non-consecutive peers, you will (I think) need to write distinct slices into multiple search sets, for example:
//project[2] union //project[6]
or
project[2] union project[6]
or, of course, you can harvest your search as a JS array, and multiply slice that:
'use strict';
xs = Application('TaskPaper')
.documents.at(0).evaluate({
script: '' + (
e => e.outline.evaluateItemPath('project')
.map(x => x.bodyString)
return [xs[0], xs[3]].join('\n');
Jim
4
Great ideas—you’ve given me some fine insights. Thank you @complexpoint!
