I have this KM macro I use to add a note to the bottom of the active project list:
The only issue it has is that if the last note/task of the active project is indented more than a project level scope (is a subtask of another note/task). This macro will create the note underneath it (as another subtask ).
Is there a way to modify above macro to insure that the note will be created at the project level scope?
Option return will create a line above the currently active line and not below it. Otherwise this solution would work. Although I bound opt+return to something (even though I donβt mind rebinding it in order to make this use case work).
