I’d love to add my custom tags so I can use keyboard shortcuts as I don’t use the default tags - Due, Today, Start, Done.
Can I override them?
Thanks
Thanks
You can write a script (to toggle a particular tag on and off in selected lines), and attach that script to a keystroke with something like Keyboard Maestro or Fastscripts.
I’m personally out of town at the moment, without a macOS machine to hand - but if no-one else has sketched a script for you by then, I should be able to take a look in the latter half of next week.
In the meanwhile, it may be worth looking at the tags section of the extensions wiki:
https://support.hogbaysoftware.com/t/taskpaper-extensions-wiki/
This script may help — it will toggle through a list of tags:
/* eslint-disable max-lines-per-function */
"use strict";
// Ver 0.02
// A bit of tidying
// - TOGGLING SELECTED ITEMS THROUGH A CYCLE OF TAGS -
// main :: IO ()
const main = () =>
Application("TaskPaper").documents.at(0)
.evaluate({
script: `${TaskPaperContextScript}`,
withOptions: {
tagCycle: [
"important",
"next",
"today",
"incubate",
"waiting",
"declined"
// -------------------- TASKPAPER --------------------
const TaskPaperContextScript = (editor, options) => {
const tpMain = () => {
outline = editor.outline,
selection = editor.selection,
tagCycle = options.tagCycle;
outline.groupUndoAndChanges(() =>
selection.selectedItems.forEach(
item => bimap(
k => k && item.removeAttribute(
`data-${k}`
k => k && item.setAttribute(
`data-${k}`, ""
foundAndNext(tagCycle)(item)
// foundAndNext :: [String] ->
// Item -> (String, String)
const foundAndNext = tagNames =>
// A Tuple of the first found tag in the cycle,
// if any, and the next tag in the cycle, if any.
item => {
iLast = tagNames.length - 1,
mbi = tagNames.findIndex(
k => item.hasAttribute(`data-${k}`)
return 0 <= iLast ? (
-1 !== mbi ? (
iLast !== mbi ? [
tagNames[mbi],
tagNames[1 + mbi]
] : [tagNames[iLast], ""]
) : ["", tagNames[0]]
// bimap :: (a -> b) -> (c -> d) -> (a, c) -> (b, d)
const bimap = f =>
// Tuple instance of bimap.
// A tuple of the application of f and g to the
// first and second values respectively.
g => ab => [f(ab[0]), g(ab[1])];
// TaskPaper context main function called.
return tpMain();
// Script main function called.
Thanks. I do use the Command + T Option but I would’ve loved to use specific key strokes for specific tags, and use that “Tag” menu item that is just sitting there unused.
