I just updated to macOS Catalina and was trying to import some reminders from the Reminders app. I thought I was able to import reminders from any list in prior versions, but now it only allows me to import from the Reminders list.
Is there a way around this so that I could import from any list? I am using the latest build of 3.8 (409).
I still see multiple lists as import options on Catalina.
Two things to check:
- Make sure that “TaskPaper > Preferences > Always use Reminders.app > Default List” is not checked
- It may be that lists only show up if they have uncompleted items, so make sure list has some items.
Thanks Jesse. It was the “Always use Reminder.app > Default List.” I unchecked that and it went back to showing all of the lists.
