Can I tell TaskPaper not to care about a capital letter at the beginning of a Tag?
These two tags are the same for me:
Sorry you can’t. I know in some cases it would be very convenient, but I want TaskPaper files to work the same. It would be weird if queries and general behavior worked one way with one preference setting and another way with another preference setting. For better or worse I decided on case sensitive tags being the standard build in behavior.
Explanation consistent… Thanks!
Why is it needed that it works the same everywhere?
For example if someone shares a search pattern, script, stylesheet, etc here in the forum it’s nice to know that everyone is working from as similar a base as possible.
