hi
! I have built a hacky script to focus specific projects but would like to be able to have multiple windows (views) into the same file.
let’s say you have a file named Notes.txt with the following content:
Notes.txt
[Wed 5/25/22 12:27AM]
here are some of my favorite things
favorite foods:
apples
bananas
favorite candies:
chocolate
mints
those are my favorite things.
and you have a script that you use as part of your workflow such that it is given some info about the path to Notes.txt and the lineNum you want to focus in.
lets say the node script looks like this:
Script.js
const {execSync} = require('child_process');
let [filePath, lineNum, charPos] = process.argv[2].split(':');
filePath = filePath.replace(/^~\//, `${process.env['HOME']}/`);
//! TODO: if the file is already open, open it again in a new window with a new view to the specific line.
execSync(`open -a TaskPaper "${filePath}"`);
/** @param {string} lineText */
const focusTaskpaperLine = async lineText => {
const runJxa = require('run-jxa');
await runJxa(`
const main = mainOptions => {
const taskpaperApp = Application("TaskPaper");
const {documents} = taskpaperApp;
if (!documents.length) return false;
const documentInjectionScript = (editor, options) => {
editor['focusedItem'] = editor.outline.items[options.lineNum-1];
const mostRecentDocument = documents[0];
const result =
mostRecentDocument.evaluate({
script: documentInjectionScript.toString(),
withOptions: mainOptions
taskpaperApp.activate();
return result;
const [lineText, charPos, lineNum] = args;
const isSuccess = main({searchText: lineText, charPos, lineNum});
return isSuccess;
`, [lineText, charPos, lineNum]);
// don't know a way to go to a specific line number, so use a line content grep hack for now
const searchText = execSync(`sed '${lineNum}q;d' "${filePath}"`).toString();
setTimeout(() => focusTaskpaperLine(searchText).then(), 500); // allow time for external edits to be loaded
currently, if the script is triggered for the line “favorite foods:” it will open that file and then focus that specific section, which is beautiful.
then if you invoke it again for “favorite candies”, it will open that file (which is already open, so it reuses that window), and then move the focus to this new section. I end up with one window which shows candies.
however, I want it to be such that if I open “favorite foods:” and that window is open, then I trigger “favorite candies:”, then I would like for it to open a new window (not another instance of the app) and have that new window focus on “favorite candies:”. I would end up with two windows, one showing foods and one showing candies.
how can i tweak my code to accomplish this desire?
thank you in advance
