As per image, I only want to see the title of the .bike document and thats it. Rest I don’t care about it as I use keybinds for it and it distracts me. I want clean UI.
Thank you lots.
Thank you lots.
I don’t think I will remove anything more at this point from the default titlebar, but for the next release I am adding Comman-. to Show/Hide all UI. So use command period to only see text, no window titlebar or sidebars at all. And then use again to show whatever UI configuration you had before.
Excited for that!
this is great
also please allow users to set this as default view on newly created/opened documents too
would be dreamy ![]()
