If you are going to use AppleScript, there are two basic patterns for finding a matching row:
either the where/whose syntax:
set searchString to "omicron"
tell application "Bike"
tell front document
set refMatches to a reference to (rows where name = searchString)
-- set refMatches to a reference to (rows where name contains searchString)
if 0 < (count of refMatches) then
set target to item 1 of refMatches
set focused row to target
name of target
else
"No row found containing string."
end if
end tell
end tell
tell front document
set matches to query it outline path "//" & searchString
if 0 < length of matches then
set target to item 1 of matches
name of target
else
"No row found matching outline path."
end if
end tell
end tell
Or in Script Editor (with language selector at top left set to JavaScript):
"use strict";
// First line of clipboard text used as Bike focal row
// (either found in front document or created at its end)
const main = () => {
bike = Object.assign(
Application("Bike"),
{ includeStandardAdditions: true }
doc = bike.documents.at(0);
return doc.exists()
const clip = bike.theClipboard();
return "string" === typeof clip
? firstLineAsBikeFocalRow(bike)(doc)(
clip
: "No text found in clipboard."
: "No document open in Bike.";
// ---------------------- BIKE -----------------------
// firstLineAsBikeFocus :: Application ->
// Document -> String -> IO String
const firstLineAsBikeFocalRow = bike =>
doc => s => {
const firstLine = lines(s)[0].trim();
return 0 < firstLine.length
bike.activate(),
doc.focusedRow = bikeRowFoundOrCreated(
bike
)(doc)(firstLine),
doc.focusedRow.name()
: "No text found in clipboard";
// bikeRowFoundOrCreated :: Application ->
// Document -> String -> IO Row
const bikeRowFoundOrCreated = bike =>
// Either the first row in the document matching
// the name, or a new row with that name,
// at the end of the document.
doc => name => {
const matches = doc.rows.where({ name });
return 0 < matches.length
? matches.at(0)
const newRow = new bike.Row({ name });
doc.rows.push(newRow),
newRow
// lines :: String -> [String]
const lines = s =>
// A list of strings derived from a single string
// which is delimited by \n or by \r\n or \r.
0 < s.length
? s.split(/\r\n|\n|\r/u)
// MAIN ---
