nikivi
1
I want something similar like
return doc.exists()
? doc.export({
all: false,
as: "plain text format"
.trim()
from @complexpoint shared in How to get current selected line as text without keybind hacks
but to get parent task
i.e. here:
I would get this value: get app.thepakt.com building with the new tanstack etc.
I think .containerRow() is the method you need:
return doc.exists()
? doc.export({
all: false,
.trim()
Another approach to these questions is to use an outline path (relative to the selected line) with a macro like the one below.
| Line(s) to copy |
Outline path |
| Selected row |
| Parent of selected row |
| Subtree of selected row |
descendant-or-self::* |
| Inclusive path to selected row |
ancestor-or-self::* |
| Exclusive path to selected row |
ancestor::* |
| Other |
Using Outline Paths | Bike |
return (() => {
"use strict";
const main = () => {
return doc.exists()
selnID = doc.selectionRow.id(),
subPath = kmvar.local_PathFromRow,
outlinePath = `//@id="${selnID}"/${subPath}`,
from = doc.query({ outlinePath }),
formatName = formatTitle(
kmvar.local_ExportFormat
return 0 < from.length
? outlineFullLeft(
doc.export({
from,
as: `${formatName} format`,
all: false
: `No matches from selection for ${subPath}`
// formatTitle :: String -> ("bike" | "OPML" | "plain text")
const formatTitle = s => {
// Normalised for API
// (defaulting to "plain text")
const k = s.toLocaleLowerCase();
return k.includes("plain") || k.includes("xt")
? "plain text"
: k.includes("opml")
? "OPML"
: k.includes("bike") || k.includes("ml")
? "bike"
: "plain text";
// outlineFullLeft :: String -> String
const outlineFullLeft = txt => {
// A plain text outline with any surplus
// indentation pruned out.
xs = txt.split("\n"),
rgxIndent = /^\s*/u,
mindent = Math.min(
...xs.map(s => s.match(
rgxIndent)[0].length
return xs.map(
x => x.slice(mindent)
.join("\n");
// MAIN ---
