I have three AppleScripts that I use to perform my GTD weekly review. They are triggered by keyboard shortcuts using Keyboard Maestro. Since I am moving from TaskPaper 2 to TaskPaper 3, I need to update the scripts. Any help is greatly appreciated.
The first AppleScript adds @review to every item:
tell application "TaskPaper"
tell front document
repeat with each in entries
tell each
make tag with properties {name:"review"}
end tell
end repeat
end tell
end tell
The second AppleScript deletes the @review tag from the current selection:
tell front document
tell selected entry
if (exists tag named "review") then
delete tag named "review"
end if
end tell
end tell
end tell
The final one removes any @review tags that I missed:
tell front document
tell each
end if
end tell
end repeat
end tell
end tell
You could write it like this (adjusting the options at the end if you want to tag projects and/or notes as well as tasks)
(function (dctOptions) {
'use strict';
// TASKPAPER CONTEXT:
var outline = editor.outline;
// for a single Cmd-Z to undo it all, if required
var strAttrib = 'data-' + options.tagToAdd;
// Get the list of lines to edit
outline.evaluateItemPath(options.linesToTag)
// and loop through them setting the data- attribute
// (user tag) that you want
.forEach(function (item) {
item.setAttribute(
strAttrib,
options.tagValue
// JAVASCRIPT FOR AUTOMATION CONTEXT:
.documents,
d = ds.length ? ds[0] : undefined;
// Pass the script from JXA to TaskPaper, with options
return d ? d.evaluate({
withOptions: dctOptions
}) : undefined;
// OPTIONS
linesToTag: '//@type=task',
tagToAdd: 'review',
tagValue: ''
The second two can be covered by making two copies of one script, editing the selectedOnly option at the end to true for the first case, and false for the case where you want all such tags to be cleared:
'use strict';
var strTag = options.tagToClear,
strAttrib = 'data-' + strTag;
// Either just the selected items,
// or ALL items with this tag
// (depending on the .selectedOnly option (true | false)
var lstItems = options.selectedOnly ? (
editor
.selection
.selectedItems
) : outline.evaluateItemPath('//@' + strTag);
lstItems.forEach(function (item) {
item.removeAttribute(strAttrib);
.documents,
}) : undefined;
// OPTIONS
tagToClear: 'review',
selectedOnly: false
Generally, when you are drafting a script like this, you can experiment with itemPaths in the search panel until you get a view which shows only the lines that you want to be affected.
In this case, if you simply want to tag all lines you might try:
