I’m trying to build a search string that returns both the results of a tag search, as well as the contents of a specific project.
Longer version:
I have a project called “## Shortstack” (the ## are because I want my tp files to work well with my markdown-aware collapsing editor). It’s my small miscellany/@doing substitute for the little things that come up across the day. I also have some tag based searches for stuff to work on today. My file looks like
Shortstack:
- thing I just remembered
- email I just got and have to answer
Project1:
- thing for later
- thing I'm working on @today
etc.
And what I want to return is
Shortstack:
Project1:
I tried
! Working @search(@due <=[d] today +24h or @today or project ## Shortstack: except @done)
but this gets me the tagged items, not the shorstack project (but oddly it does return the saved search line for reasons I don’t understand).
I suspect there’s a way to do this with the tp search syntax that I’m not getting. Any ideas?
Ah yes! Union! That was the magic word. Thank you so much.
(side note, you have extraneous parenthesis in your example that break the search. I figured out to take them out, but they might confuse other people coming to this thread)
(And you are quite right, of course, grouping parentheses are not strictly needed there – I personally use them out of habit in case I want to add to the complexity of the filtering at that point)
