for example, I have one task:
- pay rent monthly @start(2021-11-01) @due(2021-11-05) @repeat(+1 month)
I want hidden this task, only show on current_date() > @start
now I can use saved search to do this, but when I use tag and projects, this task will show, is any good method that can hide the not-start-task at any place?
I have some ideas:
- global search?
- use script move theme to another document
- maybe TaskPaper 4 ?
Does TP support recurring tasks? I didn’t know that
thank you very much, I try to use search, but it is not convenient, when I click tag it will hide, even I enable maintain search option, this option will bring other not convenient behavior, I am not sure maybe has other solution, but still thank you!!
I use repeat script to do this
ah right - tx! Don’t know why I didn’t consider that there would be a script for that.
