I’m moving lists from various programs, many of which feature the now seemingly-standard “quirky” MD-lite text editors. What are the good ways to select all the empty lines in a .bike file?
I tried copying and pasting a black line in the search field. I tried Regex for \n and \r and matched nothing. Which likely informs you as to my level of RegExpertise, which has stalled at around the third quintile, gazing lustily at LookAheads.
broadly, you can get a reference to all blank lines with an expression like:
doc.rows.where({name: ""})
and you call that function reference and convert it to an Array of results by appending ()
So, for example:
"use strict";
bike = Application("Bike"),
doc = bike.documents.at(0);
refBlankRows = doc.rows.where({name: ""}),
listOfBlankRows = refBlankRows();
return [
Automation.getDisplayString(refBlankRows),
typeof refBlankRows,
Array.isArray(listOfBlankRows),
`Count from function reference: ${refBlankRows.length}`,
`Count from derived array: ${listOfBlankRows.length}\n`,
"IDs of all blank lines:",
refBlankRows.id()
.join(" ")
].join("\n\n");
and in terms of AppleScript:
Expand disclosure triangle to view AppleScript source
tell application "Bike"
set doc to front document
if doc exists then
tell doc
set refBlankRows to a reference to (rows where its name is "")
-- IDs of all blank rows:
id of refBlankRows
end tell
else
"No document open in Bike"
end if
end tell
