Out of the box, Pandoc already does a useful job of translating .bike files directly to formatted MS Word .docx files.
If we start with a Bike file like:
then, with pandoc installed (e.g. with brew install pandoc) the command line:
pandoc -f html -t docx note.bike -o note.docx
creates an MS Word file like:
In which only the highlight formatting ( underlying <marked> tagging) has not been translated automatically.
I haven’t, so far, experimented with customizing pandoc outputs, but it does appear to be possible. The .docx XML markup that we would need to generate, for example, has this kind of pattern:
<w:r w:rsidRPr="00F12617">
<w:rPr>
<w:highlight w:val="yellow"/>
</w:rPr>
<w:t>marked</w:t>
</w:r>
More generally, pandoc translates bike files to an intermediate (JSON-formatted abstract syntax tree) format which can be represented (and post-processed) in JavaScript or Lua etc. For example,
pandoc -f html -t json note.bike -o note.json
Gives us the JSON representation below which:
- preserves the
<mark>tagging for the highlight format, and - should allow for transforms like designating the top N levels of an outline as heading levels, etc
Expand disclosure triangle to view Pandoc JSON AST source
"pandoc-api-version": [
1,
22,
2
"meta": {},
"blocks": [
"t": "BulletList",
"c": [
"t": "Div",
"c": [
"P9",
"t": "Para",
"c": [
"t": "Str",
"c": "Various"
"t": "Space"
"t": "Str",
"c": "inline"
"t": "Space"
"t": "Str",
"c": "formats"
"t": "BulletList",
"c": [
"t": "Div",
"c": [
"vi",
"t": "Para",
"c": [
"t": "Span",
"c": [
"t": "Str",
"c": "alpha"
"t": "Space"
"t": "SoftBreak"
"t": "Strong",
"c": [
"t": "Str",
"c": "bold"
"t": "SoftBreak"
"t": "Span",
"c": [
"t": "Space"
"t": "Str",
"c": "etc"
"t": "Div",
"c": [
"Ru",
"t": "Para",
"c": [
"t": "Span",
"c": [
"t": "Str",
"c": "beta"
"t": "Space"
"t": "SoftBreak"
"t": "Emph",
"c": [
"t": "Str",
"c": "italic"
"t": "SoftBreak"
"t": "Span",
"c": [
"t": "Space"
"t": "Str",
"c": "etc"
"t": "Div",
"c": [
"il",
"t": "Para",
"c": [
"t": "Span",
"c": [
"t": "Str",
"c": "gamma"
"t": "Space"
"t": "SoftBreak"
"t": "Code",
"c": [
"code"
"t": "SoftBreak"
"t": "Span",
"c": [
"t": "Space"
"t": "Str",
"c": "etc"
"t": "Div",
"c": [
"uA",
"t": "Para",
"c": [
"t": "Span",
"c": [
"t": "Str",
"c": "delta"
"t": "Space"
"t": "SoftBreak"
"t": "Strikeout",
"c": [
"t": "Str",
"c": "strike"
"t": "SoftBreak"
"t": "Span",
"c": [
"t": "Space"
"t": "Str",
"c": "etc"
"t": "Div",
"c": [
"V3",
"t": "Para",
"c": [
"t": "Span",
"c": [
"t": "Str",
"c": "epsilon"
"t": "Space"
"t": "SoftBreak"
"t": "Span",
"c": [
"mark"
"t": "Str",
"c": "marked"
"t": "SoftBreak"
"t": "Span",
"c": [
"t": "Space"
"t": "Str",
"c": "etc"
"t": "Div",
"c": [
"du",
"t": "Para",
"c": [
"t": "Str",
"c": "zeta"
"t": "Space"
"t": "Str",
"c": "plain"
"t": "Space"
"t": "Str",
"c": "etc"
