@jessegrosjean Is there any way of applying formatting according to the level or child dependency a task is?
There is a depth
attribute. For example:
item[depth=2] {
color: green;
That’s great, thanks. Does this apply within each element (as opposed to general statements to the editor) so I can say;
Project
color: blue;
item[depth=2] {
color: green;
Task
color: Purple;
item[depth=2] {
color: Orange;
Not using those colors but trying to clarify my question.
I think you want this:
item[data-type=project][depth=2] {
color: green;
item[data-type=task][depth=2] {
color: green;
OK, then it has to be two (or more) of them. For code efficiency I try to compact a statement once it is working.
// Changes the Task Font.
item[data-type=task] {
font-size: 18;
line-height-multiple: 1.2;
color: mix(white,green, 50%);
paragraph-spacing-before: 15;
color: red;
item[data-type=task][depth=3] {
color: red;
item[data-type=task][depth=4] {
color: red;
