The Format (as task, project or note) menu does nothing on my system - for both 166 and 167 builds.
Thanks, I’ve fixed this for the next release.
Thanks for the quick fix.
The Format (as task, project or note) menu does nothing on my system - for 417 build.
…as previous shortcuts (build 341 for example)
This seems to be working normally for me in both 417 build and latest preview release. Two things to try:
- Make sure text area has keyboard focus, otherwise those menus are disabled.
- Try restarting TaskPaper?
I’m very sorry Jesse, certainly in the previous build these shortcuts was a my personalization. I just recreated them: https://support.apple.com/guide/mac-help/create-keyboard-shortcuts-for-apps-mchlp2271/mac
They are very useful in my workflow. Thanks… and I’m sorry again
