When I do the ever-popular Command-P to print, I get the focus menu. There doesn’t appear to be a keyboard command for printing. Need that!
This is a design decision… there are only so many good keyboard shortcuts and I feel like focusing using a keyboard shortcut is more important in Bike then printing using a keyboard shortcut.
With that said, on macOS you can assign your own keyboard shortcuts using system preferences. Using that method you can assign Command-P to printing, and passing something else to focus.
Use macOS keyboard shortcuts - Apple Support.
Hope that helps!
