Feature Request for Bike (and WR perhaps) - dot next to filename
Feature request:
Is it possible to include a dot or (Edited) next to the filename on the tab to indicate the file has not been saved? I often keep 6-7 Bike files open and it would be nice to rapidly see which of them is unsaved short of tabbing through all open windows and checking individually.
The documents are always autosaving in place (using standard macOS autosave), dot edited status isn’t needed I think and was generally removed from macOS in 2011. Some related discussion:
When a document shows “Edited” in titlebar that really means that the “version” has been edited from previous version. But any changes you make are autosaved into this new version. Saving is more creating a checkbox that you can version back too.
Maybe you already know all this… but I don’t think it would be helpful if my apps acted different from all the system apps, TextEdit, etc. in this respect.
All this makes sense, thanks. Yes, I’m still a bit paranoid about saving as much possible, old habits and all that lol
