Feature request: Command click to select multiple rows
Would it be difficult to add the feature to Bike—common in other similar apps, I believe—to be able to select multiple rows at the same time using either Command-Click (for non-adjacent rows) or Shift-Click (for adjacent rows)? I hope that makes sense. I miss being able to do that in Bike compared to, say, OmniOutliner or MindNode.
Some discussion here:
The tradeoffs changed a bit in 2.0 codebase. The selection model is better suited to support discontinuous row selection, but it’s still not something that I’m working on yet. Maybe post 2.0 I will look into it again.
Great, thanks for the update.
