Hi
One of the features I’d love is the ability to remove the default “@” tags e.g. @due, @done, etc in the sidebar.
This is because sometimes we use Taskpaper as away of categorising information and not just as a “Todo list”.
I understand that the “todo list” is the default workflow, but it would be great to have the flexibility to remove the default tag listing too.
Many thanks
There are configuration files that allow you to change this:
https://guide.taskpaper.com/using-taskpaper/using-the-sidebar.html
Instructions are hidden away at the very bottom of that page.
Perfect, just what I needed.
Many thanks! Keep up the good work.
Ben…
