However, nothing I do can get this shortcut to actually execute. This has worked in previous builds. I don’t see anything particularly helpful in the Logs Explorer.
Please let me know what/if any additional info I can provide. Thanks!
Ah, thanks I will fix. I don’t think it’s keyboard shortcut related, instead just some commands are not working due to a bug. For example toggle sidebar also won’t work when you selected from commands palette, but will work from menu item which uses a different path.
however, i tried implementing it with cmd-shift-[, and instead of opening the sidebar, Bike cycles through the tabs (despite Next/Previous tab having different shortcuts)
