@jessegrosjean , could you tell me if there any difference between Edit > Copy and Edit > Copy as displayed when there is no selection ? I would expect the latter to copy everything currently shown in the editor.
In the meanwhile, a default Copy All as displayed might, I think, look something like the script below, if run from an Execute JXA action in Keyboard Maestro, with output sent to the clipboard.
(Custom variants, for example with 4-space indentation, or outline syntaxes other than TaskPaper’s, could also be sketched as scripts)
(For other options, see Using Scripts · GitBook )
'use strict';
// main :: IO ()
const main = () => {
const ds = Application('TaskPaper').documents;
return either(alert('Problem'))(x => x)(
bindLR(
ds.length > 0 ? (
Right(ds.at(0))
) : Left('No TaskPaper documents open')
d => d.evaluate({
script: tp3Context.toString()
const main = () =>
Right(
ItemSerializer.serializeItems(
editor.displayedItems,
editor
// ------------------- GENERIC -------------------
// Right :: b -> Either a b
const Right = x => ({
type: 'Either',
Right: x
const alert = title =>
s => {
const sa = Object.assign(
Application('System Events'), {
sa.activate(),
sa.displayDialog(s, {
withTitle: title,
buttons: ['OK'],
defaultButton: 'OK',
withIcon: sa.pathToResource('TaskPaper.icns', {
s
// Left :: a -> Either a b
const Left = x => ({
type: 'Either',
Left: x
type: 'Either',
Right: x
const bindLR = m =>
mf => undefined !== m.Left ? (
m
) : mf(m.Right);
const either = fl =>
fr => e => 'Either' === e.type ? (
undefined !== e.Left ? (
fl(e.Left)
) : fr(e.Right)
) : undefined;
It should be that both Copy and Copy Display do nothing when the selection is empty. I see that right now “Copy Display” isn’t disabled when there is no selection… it should be and I will fix that.
The difference between Copy and Copy Displayed is how they handled folded/filtered regions. For example if you fold items in your editor… and then “Select All”:
- Copy will copy the folded content that you’ve selected
- Copy Displayed will only copy the visible content that you’ve selected, folded/filtered content will not be copied.
I hope that helps!
Thank you, @jessegrosjean. That is helpful !
@complexpoint, thank you so much for the script and the outstanding things you share here ! Really appreciate it
“Copy Displayed” should now be disabled in latest release when selection is empty:
