Hi, I’ve found a bug where the children of a collapsed row are not copied.
I’ve attached a link to a screen recording of the issue
Rows B and C both have children and are collapsed.
I am only selecting and copying rows A,B and C.
The children of row C do not get copied.
If I include row D in the select and copy then the children of row C do get copied.
So it looks like it is connected to C being the last row in the selection.
So it works if I include the newline at the end of the row, so not a bug, but a bit of a gotcha.
When drag selecting, the cursor has to start/end at least a little bit below the last line to include the newline which is the same behaviour as TextEdit so expected behaviour.
I guess a solution might be to include the children of a collapsed row if the the whole row is selected even if that doesn’t include the new line?
