Collapse by level - UI glitches?
Not sure if this was always the case, but collapsing by level on 182 has this strange UI effect:
CleanShot 2024-09-23 at 21.46.59
Perhaps a discussion for a different topic, but related to collapsing by level:
Tana’s outliner has the ability to collapse/expand child rows by keeping the cursor on the parent row, and then toggling the shortcut for (single) row expansion. Same in reverse. I wonder if there is a use case for this shortcut economy in Bike, too (I’m also not sure if Tana’s design was intentional or not - no other outliner I use does this).
CleanShot 2024-09-23 at 21.52.59
Not sure if there is a word missing there ?
(you mean column 182 ? Presumably not level 182 ?)
No, the number of the preview version.
Thanks I can reproduce this and am looking into it. Also thinking about collapse idea.
Dug more into this. What I’ve found is:
  1. I think the glitch has been in all versions that support collapse by level
  2. It’s certainly not ideal, but it corrects itself after a moment, and only shows up if you collapse by level multiple times in quick succession.
  3. Hard to fix, I tried a few things, but they all broke some other animation
  4. Glitch is already fixed in 2.0 codebase due to new design
End result is I think I will leave this as is.
A post was split to a new topic: Simplify Bike’s expand/collapse commands
