⌘ + click any part of link to open?
Tiny thing — I was mildly surprised I had to explicitly click the arrow next to the link even as I held down ⌘. I would expect holding ⌘ to let me click anywhere on the link to open it.
Is this something that other apps do? Allow you to click in the link text with normal clicks, but activate the link when command clicking? If it’s a standard convention then I can see adding it, but it makes the current story (click arrow to open link) more complicated.
Most other apps I’ve used (Notes, Obsidian, Bear) don’t have a trailing icon and allow you to click anywhere on the link to open.
I’m on mobile now so am trying to remember, but usually it’s:
  • ⌘ click to open, or
  • right-click to see a context menu item to open the link
(I think those are right; they may not be!)
